PV500 (lines where the colour contrast changes)
Discussion in 'Plasma TVs Forum' started by chaddy, Aug 11, 2005.
  1. chaddy
    chaddy
    Jul 7, 2005
    1,620
    48
    Manchester
    +66
    Hi peeps, i've had my pv500 for about 2 months now. I'm just wondering what are the best setting in the picture setup.
    At the mo i'm getting lines where the colour changes its shade (i.e on faces i can see where the colour is changing).
    so i'm just wondering if if got my contrast and brightness wrong.
    I have this problem on my 17" Grundig LCD, but i expect that with it having a 500:1 contrast ratio.
    At the mo i have it on these settings.
    [​IMG]
    Any help would be great.
    I'm using QED SQART P2110.
    Sky to av1
    cheers.
    Hope to have it sorted for start of prem season at 12.00pm
  2. Korum
    Korum
    Feb 19, 2005
    4,352
    Stockton-on-Tees
    +701
    My Setup is:
    From zero
    contrast +42 notches
    brightness +28 notches
    colour +35 notches
    sharpness +3 notches
    colour balance cool (normal gives a yellowish tinge to whites)
    colour management off
    both NR's off
    My setup has the contrast set quite high but I've run it in for 300 hours and these settings are spot on IMO.
  3. chaddy
    chaddy
    Jul 7, 2005
    1,620
    48
    Manchester
    +66
    cheers will try
  4. Korum
    Korum
    Feb 19, 2005
    4,352
    Stockton-on-Tees
    +701
    Oh forgot to say viewing mode:cinema seems to produce the best all round PQ.
  5. chaddy
    chaddy
    Jul 7, 2005
    1,620
    48
    Manchester
    +66
    anybody is welcome to give there settings.
  6. Korum
    Korum
    Feb 19, 2005
    4,352
    Stockton-on-Tees
    +701
    chaddy, there are loads of threads on here regarding the setup of PV500's
  7. chaddy
    chaddy
    Jul 7, 2005
    1,620
    48
    Manchester
    +66
    ah, ok i'll a search
  8. chaddy
    chaddy
    Jul 7, 2005
    1,620
    48
    Manchester
    +66
    korum, whats your settings for dvd.
    I'm using mark grant compnant cables.
  9. Korum
    Korum
    Feb 19, 2005
    4,352
    Stockton-on-Tees
    +701
    The settings I use are for all my inputs,I only use cinema mode so I'd have to change the settings every time I put a different AV channel on as the PV500 only saves changes to cinema, normal mode etc not individual inputs.
    I have Sky on AV1, Xbox and Pioneer 575 on component and I've found all of them to look superb with these settings.I used the THX optimiser to setup initially, I know it's basic but It seems to work very well. I also lowered the green drive in the service menu as IMO the greens are a tad too high by default,I don't know if you are comfortable messing around with these menu's.
  10. k0rn
    k0rn
    What do you mean? The color banding? If so, then your set is probably faulty? This has nothing to do with any settings you can do...
  11. Korum
    Korum
    Feb 19, 2005
    4,352
    Stockton-on-Tees
    +701
    Yeah, agree with k0rn.I've seen no colour banding on my set.
  12. chaddy
    chaddy
    Jul 7, 2005
    1,620
    48
    Manchester
    +66
    i don't know what its called, its like when a face comes on the screen and takes up most of it i can see shading of all the colours of the face. it dosen't seem to blend in smoothly
  13. chaddy
    chaddy
    Jul 7, 2005
    1,620
    48
    Manchester
    +66
    Also just watching the grudge, it seems to be a bit grainy. I don't know if it was filmed in that way, i've played stuff like spy kids & finding nemo & i get a cracking picture out of that.
  14. MokerJoker
    MokerJoker
    Dec 10, 2002
    130
    +6
    Seems similar to what I've noticed. See my post with pics in http://www.avforums.com/forums/showthread.php?t=224055&page=4
    Korum: I am pretty sure my PV500 remembers the settings for each input and even for each mode.
  15. Korum
    Korum
    Feb 19, 2005
    4,352
    Stockton-on-Tees
    +701
    Jvwaard, my pv500 doesn't do that.I've got it on Cinema mode on every input and if I say reduce the brightness on AV1 the change is also there on AV2,Component etc.It's a shame it doesn't remember the settings for each individual AV1 channel.
    The only way I could have different contrast/brightness etc on AV1 and component is to set AV1 to 'normal' mode and component to 'cinema' mode.
  16. MokerJoker
    MokerJoker
    Dec 10, 2002
    130
    +6
    That is strange and maybe faulty. I have just checked my PV500. It keeps different settings on all inputs. I only use Normal mode and it remembers all settings for each input, including different settings for Component, PC and HDMI. And if I change one of the inputs, the others do not change. Tried it with different modes, including Cinema. Only the aspect ratio is not remembered. I have an EU-model, maybe the UK model is different (firmware)?
    - Jerry
  17. Korum
    Korum
    Feb 19, 2005
    4,352
    Stockton-on-Tees
    +701
    That's interesting Jerry, I've got the 'B' model and it doesn't store the settings like your's, can anyone else comment who has a 37 or 42PV500B.
  18. FlyingBig
    FlyingBig
    Apr 11, 2004
    545
    Lisburn
    Out of interest did that eliminate the green tinge you get around fast moving objects? Cheers.
