PV500 - How do I connect 2 or 3 x Component sources?
Discussion in 'Plasma TVs Forum' started by robo989, Aug 8, 2005.
  1. robo989
    robo989
    Feb 14, 2004
    2,695
    68
    Carmarthen
    +70
    Hi I'm a little confusded on this, I just ordered my PV500 42 incher (yahoooooo!!!) never owned a plasma before but...
    I just spent £115 on cables including
    1x Playstation 2 component cable
    2x Profigold component cables
    Obviously the Playstation 2 cables purpose needs no explanation, the other 2, 1 is for my Pioneer-575A and the other for the Panasonic DMRES10 dvd recorder that I ordered with the plasma...
    But hasn't the PV500 only got 1 set of component inputs? oooopps...
    Is there an easy way around this through the use of some switcher box or something? I have no clue myself? Are there ones available that would do the swiching automatically....
    ah no I'm a foool, I just remembered that my amp can take 2x component and has 1 output but doesn't that mean that I'll still need one more?
    Thank you for any advice :)
    Rob
  2. Korum
    Korum
    Feb 19, 2005
    4,352
    Stockton-on-Tees
    +701
    I use an Audio Authority 1154A switcher box.It handles 4 component inputs,Auto switches them and also switches optical/coaxial/analog sound for each source.Superb piece of kit.You're looking at over £100 for one though.
    Unless you have an NTSC PS2 I'd ditch the componrnt for that and use an RGB Scart instead as there's no PQ difference in the 2 cables unless you have access to 480p NTSC Titles.
  3. the highlander
    the highlander
    Mar 29, 2005
    177
    Bonnie Banks O' Loch Lomond
    i use THIS works a treat. :smashin:
  4. robo989
    robo989
    Feb 14, 2004
    2,695
    68
    Carmarthen
    +70
    thanks for your posts,
    yeah that thing looks good, £55 aint "too" much I guess...
