Pv500 Hdmi Set Up
Discussion in 'Plasma TVs Forum' started by srodwell, Aug 12, 2005.
  1. srodwell
    srodwell
    I need some help with my HDMI set up
    I'm getting the black bars at the top and bottom of the picture whilst playing a 16.9 aspect film.
    Is their anyway to fill the screen?
  2. Korum
    Korum
    Feb 19, 2005
    4,319
    Stockton-on-Tees
    +701
    I presume you mean when you play 2:35 aspect movies ?
    If your player is scaling the image up to 720p then I'm afraid you're locked on one aspect ratio.The PV500 will only allow you to use 16:9 ratio on HD 720p material.Press the 'i' button on your remote when the movie is on if it says 720p in the top left corner you're locked into 16:9.
  3. seasider2
    seasider2
    Jul 19, 2005
    65
    I actually get this when viewing dvds via component. Using the Scart the TV automaically adjusts itself to fill the screen - is there a reason why Component doesn't?
