FlyingBig
Anyone managed to get their xbox running fine using component (microsoft hi-def kit) without the faint vertical bars/lines running the down the screen? So far Scart works perfect but i have tried nearly every combo with the hi-def kit and no luck. I am going to try to connect the xbox via vga to see if that helps. In the mean time any help would be appreciated.
