Pv500 Dvi>Hdmi
Z
Zeggi
Hey!
ive got a 42pv500 and ive just built a media center, a barbone computer with a asus 6600gt card... now my problem is the following, ive just bought a supra cable dvi2hdmi its a clean cable no adapters or stuff in bettwen..
now when using the media center for 5mins i get a lot of faults, distoring in green colour... and sometimes i get like a green pixel map all over the screen, all the distortion is green and white.. now im wondering why am i getting this?
and if anyone else here has the same problem?
any tips/recomendation is appreciated
i havent tested it with my ptae700 i will do that as soon as i get the chance.
thanks!
irishguy2002
I've only ran the pc via - VGA.
I was thinking of running my pc via DVI - HDMI, however it does state in the manual that the HDMI input is not designed for PC's.
I have the 37PV500.
VGA looks pretty good running DIVX HD and HD Stuff.
What type of DVI-HDMI cable are you using, where did you get it?
There are so many different cables @ different prices some 20 some 90 for a dvi - hdmi cable.. not sure if the type that you got was a cheapo version?
Paul
Z
Zeggi
its a Supra cable, and it went for 350sek thats about 35e
and its recomended by users..
the Vga cable works but it doesnt deliver hdtv :(
its analog so you dont get to see that in true hd qual
M
mork80
I've bought a DVI2HDMI cable on eBay for almost 20euros and works great !!! Perfect pictures and amazing HDTV 720&1080 (mostly trailers downloaded from web).
TheaterTek DVD player thru my HTPC is even better than any RGB commercial DVD player.
NonPayingMember
Previously Liam @ Prog AV
Could it be a graphics card fault? I assume you are sending 1280x720p resolution. If you go into the VGA you can send 1024x768 meaning no rescaling is going on in the panel at all. Try it with a decent VGA lead, you won't be able to tell the difference between analogue and digital once properly configured.
irishguy2002
Yes,
I agree it looks fantasic on using my vga currently, not sure what the jump will look like on DVI-HDMI - it should be better.
However I think I have properly configured my box and it looks stunning..
NonPayingMember
Should be, but probably won't. Panasonic DVI implementation is not better than analogue on the pro monitors, I would expect the same of the TVs. Add to this the fact that the TV wil have to rescale 720p on HDMI and in actual fact the picture will probably be worse!! A fresh digital picture looks great at first, but once you setup your contrast/brightness/colour etc it looks no better than VGA.
Z
Zeggi
hmm well looking @ vga and hdmi u can see that the hdmi is way much more sharper, almost to sharp specially when it comes to text..
about the gfx card, when setting the rez @ 1024*768 the plasma strecthes the pic to much so you cant see the whole start bar, so i switch to hdtv signals and put it @ 720p which then lets me see everything but still i can also strecth it a bit, but that doesnt matter since the faults i get come when im using the hdmi..
Z
Zeggi
ok but, vga doesnt let you see hdtv qual right? since it is analog? or am i wrong now
irishguy2002
Well component is analog...
I'm running HI DEF DIVX / Movies through my xbox and they look the same as the PC, although the playback is jerky the quality is the same.
I ran the movies from divx.com/hd and they look sweet...
Anyways it looks great - I'm happy so I think that's the main thing!
I love tweaking stuff to the max as well to get the best quality but at the end of the day you have to sit down and enjoy the thing that you are watching/playing.
There seem to be alot of people on this site who are more interested in getting the perfect picture and not enjoying it!!
Thanks my 2 centz ..
Z
Zeggi
irishguy2002, so your recomendations are to run with vga?
cause sure i could live with that, but the question is will the signal from the pc >plasma/projector show 720p? when lets say watching a divx tvseries...
if not will the qual be any near the 720p specs?
cause i could live with that.. and yes im not only going for what specs and people say, of course my eyes controll whats best viewing and whats not... thats why i bought the panny instead of the lg
irishguy2002
Well I'm running with DVI now...
I have alot of picture problems i.e. getting the right vert horz sync.
The screen is sharper than vga but I have not really seen much difference to that of vga...
I'm sure once I get the screen settings perfected it will give an overall better quality picture but to be honest there doesn't seem to be a great deal of difference when sitting a metre away from the screen.
I'm using powerstrip to create custom resolutions for my ati graphics card on my laptop.
I will report back...
Z
Zeggi
ok now ive tried with the projector and well i have no problems there with the dvi2hdmi :/ so that means that the plasma isnt working that well or something else...
i did what you said, i tested with vga and compared and i must say NO!
to linear... i see a bunch of faults and colour isnt that great, thats only my opinion..
im using a nvidia card and well as i said it worked on the projector and hey 1080i wasnt that bad with +100" screen.
Another thing that came to my mind, i read something about xbox users using the HD cable set, the component and getting lines up/down in the background still lines.
and well i got the same with my xbox, first i thought it was my cable set but now with the projector connected with dvi2hdmi i saw the same fault. noticed it alot when runing windows media center, any clue why? a setting or a fault? bad cable?
MAW
Problem is, compared to a projector, plasma simply aint that great! Also, is your projector not 1280/720 native? The plasma is not, and you can't get native on HDMI, it simply can't be done. Native res is VGA only, and you most certainly can see all of HDTV resolution on VGA. They've been doing it that way in the states for years. It's hollywood muscling in that has instigated HDMI, it's a grotesque marketing con, which says digital is better, but is actually about copy protection, and naff all to do with quality. Yes, digital 'should' be better, but only if it's native res, and it's not, except to your projector. If you really want a PC based system, you should have bought a different screen if you want digital nirvana. Or just do VGA, it'll be pretty good anyway.
irishguy2002
MAV is correct...
Hi Def on DVI/HDMI looks great on HD Sources (albeit cropped!!)
If it aint Hi Def i.e. DVD/Divx etc... then it looks much better on vga a little less colourful and grainy (only a little) but poorer sources look much better.
Probably better off sticking to vga (pq is not too different) and use a hardware based device to pipe out HD signals.
Going to switch back to vga for the moment.
Must try my xbox component leads now...
MAW
Now imagine what all your sources might look like scaled to native res on VGA with full picture control, per input, colour, contrast, brightness etc. I'm watching 5th gear like that now, with a scaler. Now imagine that calibrated to ISF standards. Stuff HDMI, get into serious high end video, that wasn't hard was it?
Z
Zeggi
well the projector does the same rez as the plasma 1024*768 hd ready
i tested the barebone computer to see if the fault was from it or the plasma/cable.
but again the picqual is better with the hdmi cable i mean its crystal clear, while with the vga its really bad ive tried all settings since you guys recomend vga, ok sure thats when it comes to HD signals, but if you compare divx/dvd with the vga and hdmi it aint that much of a difference, sure you have to change contrast/light etc but still i see it better with hdmi since it does deliver same qual + better for hdtv use... im talking about the plasma now, the projector is connected to the xbox and that works great. except for recent linear faults.
irishguy2002
I did notice that my DVI cable was a bit faulty and had the issues with the green screen and various other problems..
The cable was not straight and when bent the picture went blank/black or crazy....
Z
Zeggi
i called panasonic today, they couldnt help me. he mentioned something about the digital settings from the computer, if they could be switched to analog i didnt understand him that well since he was norweign. but still he didnt know what to help with. so im stuck, only way is to test it with a dvdplayer and see how that works :/
no i have to get me a dvdplayer with hdmi out :S
A
avman69
I have had a PV500 for some time now and have had my P.C. connected via both vga to vga & dvi to hdmi. When i started with the hdmi it was overscanning both desktop & in games. I downloaded the latest video drivers from nvidia which allowed me to underscan the desktop to 1216*684. Now the desktop is perfect fit.
When i did this, it became a res that i could select to choose on both half life 2 & far cry. For non widescreen games i went in & edited the ini or config file to change the res to 1216*684 & also changed the field of view to give the proper widescreen aspect.
I have to say that I have had vga connected at native res 1024*768 1:1 pixel mapping & the hdmi at 1216*684 scaled & my findings are that the hdmi digital is sharper & clearer for games mentioned.
A
avman69
pc desktop was set to 1024*768 via vga to vga which is the native res of the panel, ie no scaling apparantly!
MAW
Yes, but that's not 1:1 mapping, the size/position probably needs adjusting with a test pattern, and then probably clock phase. Then you'll see a difference.
A
avman69
Maw we have got to look at ways to get a good widescreen image on these panels as that is the way all these games are going, both on P.C. and next gen consoles, also non widescreen games look crap on widescreen panels, fat squashed characters running about. No amount of test patterns or clock phase adjustments fix that. Also im afraid there is no widescreen res for games that wont require some scaling away from the native res of a panel
Klipsch The Sevens Powered Speaker Review Coming Soon
Back
