PV500 - Auto Switching
Discussion in 'Plasma TVs Forum' started by nheather, Jul 5, 2005.
  1. nheather
    nheather
    Oct 6, 2004
    17,248
    167
    Horsham, West Sussex
    +6,547
    I want a PV500 and will use the following inputs
    Sky+ on AV1 (SCART RGB)
    DVD on Component
    Will move to Sky+ on HDMI in due course.
    The only annoying feature is that I want the home cinema to be simple to use - press a single 'DVD' button on my pronto to set up all the devices - but there is a strong possibility that the PV500's awful input selection method won't support this.
    I have just spoken to a salesman who may have an answer but I'm not convinced so seek your advice.
    He said that when I switch the DVD on, the PV500 would automatically switch to the correct input. I thought this only worked with SCARTs but he assurred me that it works with Component and HDMI aswell.
    Firstly - is he correct?
    If it does then I guess if my family religously switch boxes off it should work but a more realistic scenario is:
    Sky+ box is left on and is used for 80% of the time.
    DVD is switched on and off as required.
    SCENARIO 1
    Sky+ is on and feeding AV1
    DVD is turned on
    QUESTION - will TV switch to component?
    SCENARIO 2
    Watching DVD
    Switch DVD off
    QUESTION - will TV switch to AV1?
    If SKY+ were on HDMI would the same happen.
    Cheers,
    Nigel
  2. Sulis
    Sulis
    Mar 29, 2004
    577
    Bath
    Dunno. I have the DVD connected to the SKY box, and the SKY box via RGB to AV1 on the PV500. When you put a DVD in, it automatically over-rides the SKY signal - when you turn the DVD off, it goes back to SKY. Seems to work.
  3. MrNPG
    MrNPG
    Apr 13, 2005
    777
    Poole, Dorset
    +63
    On my Panny, it definately does NOT auto switch to component input when I turn on the DVD player. I have to manually select the AV input using the TV/AV button on the remote.
  4. Jazz Monkey Jr
    Jazz Monkey Jr
    Jan 10, 2005
    14,242
    2
    4
    137
    Garstang, Lancs
    +1,625
    Component doesn't support Auto switching, nor aspect switching.
  5. Sulis
    Sulis
    Mar 29, 2004
    577
    Bath
    Is component really that much better than RGB? Hard to see how it could make much difference - the picture looks great already.
  6. chedmaster
    chedmaster
    Jan 29, 2005
    2,661
    68
    +28
    component does support automatic aspect switching, in line 23(?) of the signal. not every tv supports it, not even the mighty pv500.
  7. Worm
    Worm
    Mar 4, 2003
    246
    +8
    I have had a 37" 500 since sat.. (and NO PROBLEMS!!)
    Anyway have JVC Dr30 HD/DVD recorder connected by component and it auto selects wide when it needs to.
  8. Jazz Monkey Jr
    Jazz Monkey Jr
    Jan 10, 2005
    14,242
    2
    4
    137
    Garstang, Lancs
    +1,625
    That's what I meant, even though, I put Alladin on tonight and on the title menu it came up with WIDE on the screen which means it detects the switching :confused:
  9. nheather
    nheather
    Oct 6, 2004
    17,248
    167
    +6,547
    Okay, bit confused by those posts ...
    Does the PV500 auto-switch on component or not ?
    Cheers,
    Nigel
  10. chedmaster
    chedmaster
    Jan 29, 2005
    2,661
    68
    +28
    lol dont listen to me i dont have one was just going by the previous post, all im saying is it is possible, and if mal and worm have experienced it then it does! however it may work on pal and not ntsc as the line coding is different. (or vice versa)
  11. av addict
    av addict
    Jan 27, 2005
    2,207
    +164
    it doen't auto switch on mine i have to press index on remote{yellow button}then scroll though to select it
  12. Enquirer
    Enquirer
    with regard to your pronto issue this might work
    I have used a set of macros that allow discrete video input selection on my (UK) Panasonic TV and I believe these might work on Panasonic plasmas
    Switching video inputs takes about half a second, during which time the TV does not respond to IR-commands. This macro takes advantage of that by having the TV/AV toggle code straight after an input selection which only has an effect if the set is in AV mode. If in TV mode, the selection is ignored leaving the set free to respond to the TV/AV toggle.
    AV1 Discrete Macro:
    N (Normalise)
    ---- removes AV input or other onscreen menu if present
    Red
    ---- brings up AV input menu in AV mode, no effect in TV mode
    Delay 50ms
    Red
    ---- selects AV1 in AV mode, no effect in TV mode
    TV/AV
    ---- is ignored during AV1 switchover if set was in AV mode, otherwise switches from TV to AV mode
    Delay 200ms
    Red
    ---- now select the right video input
    To select AV2, 3 and 4 simply change the last Red to Green, Yellow or Blue respectively.
    This macro cannot discretely switch between composite and S-Video mode on AV2, 3 or 4 (you'll have to use the appropriate Fastext button.)
    replied to your post on RC too :D
  13. nheather
    nheather
    Oct 6, 2004
    17,248
    167
    +6,547
    Enquirer
    Thanks for the info, I'll have a play with this but I fear that it may not be a solution for the PV500.
    There are two 'difficulties' with the PV500
    The first is that it has more inputs than colours (5 rather than 4 in your case) so the input selection spans two menus
    (Menu 1)
    Red - AV1/S
    Green - AV2/S
    Yellow - AV3/S
    Blue - Next
    V
    (Menu 2)
    Red - Back
    Green - AV4/S
    Yellow - Comp/PC/VGA
    The TV remembers your last selection so which of these colour menus you get when you press 'TV\AV' depends on what you last selected.
    The second (as you pointed out) is that each input as 'sub-inputs'. This means that once you have got to (Menu 2) you have to scroll through the 'Yellow' to select Component, PC and HDMI.
    Again the PV500 remembers your last selection, so the number of times you have to press the 'Yellow' button depends on what you were last watching.
    Example, consider the following examples
    Example 1
    Watching TV, last watching AV1, last special input was 'Component'.
    To select HDMI
    TV/AV > Blue > Yellow > Yellow > Yellow
    Example 2
    Watching TV, last watching AV1, last special input was 'HDMI'.
    To select HDMI
    Example 2
    Watching TV, last watching HDMI, last special input was 'HDMI'.
    To select HDMI
    TV/AV
    The scenarios could go on, producing many different sequences.
    Cheers,
    Nigel
  14. Enquirer
    Enquirer
    when you press N then red before TV/AV does it not put it in a known state? from that known state you then can use a macro.This conversation is a bit Remote :D for here and will bore the pants off many! we should chat on the other forum
    Mr G
