PV500 and General Plasma FAQ - please read before posting
Steve_P
Good effort Mal :thumbsup:
Just one point though, the last item re Samsung seems to be missing a link? :confused:
Let's hope it's stickied, might cut down on the glut of PV500 threads.
S.
Steve_P
chedmaster
mal600908 said:
Are there any more plasmas to consider?
There is the Panasonic panels coming out Spet time, and the new Pioneer plasma's are coming out then aswell.
what about the current pioneer plasmas and the current pd7200
ikon66
as the chedmaster dons his flamesuit :rotfl:
Jazz Monkey Jr
willardone said:
Hey Mal,
bet you wish you posted this earlier!!!! :D
very good info for people who are interested in the pv500 :thumbsup:
I have been meaning to do it but not had the time...
Badger0-0
Should be adapted for other screens too, IMO.
Good post mate :thumbsup:
mickyd67
What about the amount of hours your screen has done?
Is there a setting that tells you that, or do you have to time it manually (i.e. keep a mental note)?
stroppygoblin
mal600908 said:
How do I check my hours/ get in to the service menu?
see HERE
Sigh :(
Worm
My Dvd /HD JVC recorder is connected by component and when it starts playin in widescreen , if the screen is set in say 4:3 it switches to wide. Is this what you are saying is not supported or is it something else?
docnaz
I have just read in "What Home Cinema" that the native resoltion of the PV500 is 4:3.
Is that true? I assume it shows true widescreen by hook or by crook?
Thanks for any answers
chedmaster
well it would be ideal to have the full 1280 horizontal but at the moment its not really worth it for the amount of money it adds to production costs. very few 42" screens have/will have the full 1280pixels for a while, so yes it is as good as any other screen in that respect.
G
gnikolaidis
Please help with the proper way to configure the connection of my DVD player to the TH-42PV500. I have configured my DVD composite output mode to "Progressive" (the default being "Interlaced"). I have used a composite cable to connect the output of the DVD player to the composite input of the PV500. However, the picture of the movie is displayed full screen, i.e. there are not the traditional black stripes on top and bottom of the screen. The input mode of the TV is set to AUTO. Is this regular or I am doing something wrong?
Mep
I suspect you mean component (3 cables) not composite, but you don't get auto aspect switching via component so you will need to set the screens aspect ratio to 16:9 (not auto) for widescreen movies.
samhain
Great effort.
If this forum has one more stupid PV500 question that has been mentioned a million times!! No one seems to enforce the search function anymore.
Again fantastic effort.
Korum
Mal, could you add to the faq the fact that Panasonic in their wisdom have removed any geometry, screen size/position settings from the service menu's on the PV500.It's staggering that they have removed these settings, potential buyers should know that if they are unhappy with screen size when using certain equipment they can't do anything about it.I would have personally not bought my 42PV500 if I had known that H-amp/V-amp had been removed from the service menu.
Thatsnotmynaim
So are you saying there is absolutely no way to adjust the size/position? :mad:
Jazz Monkey Jr
Have you had this confirmed by Panasonic?
Korum
There's been a rumour of a 'manufacturers menu' that adjusts geometry but even the panny technician mentioned in the thread wasn't authorised to access the menu.
All I want to do if overscan the image, It seems only a selected few have access for some bizarre reason, hopefully it'll all be revealed by someone further into the PV500's life.
Jazz Monkey Jr
I had Gordon round tonight to have a play with my PV500 and he couldn't adjust the overscan, which it does do quite a bit on this plasma.
I am sure something will come up how to get into another menu...we will just have to wait.
Podcast: Reported HDMI 2.1 bugs, Audiolab Amp & LG LED Projector reviews + Best of the Month
Latest News
What's new on Sky and NOW TV UK for November 2020
  • By Andy Bassett
  • Published
AVForums Podcast: 28th October 2020
  • By Phil Hinton
  • Published
Tom's Thumbs: What is coming to Netflix in November 2020
  • By AVForums
  • Published
Melco anniversary edition N10 library announced
  • By Andy Bassett
  • Published
What's new on Disney+ UK for November 2020
  • By Andy Bassett
  • Published
