pv500 and 1080p
Discussion in 'Plasma TVs Forum' started by jtf, Sep 24, 2005.
  1. jtf
    jtf
    Nov 19, 2004
    220
    colchester
    +7
    i have found a download for gladiator that says it 1080p and seeing that it is nearly 22gb it quite believeable. does anybody know if the 42pv500 is capeable of displaying this resolution. it will played from my pc via vga.
  2. crank
    crank
    :smashin: Any chance of you sending a link jtf to this download :lease: I've heard its something special.I also own the pv500 so would like to know if this would work :D come on :lease: guys
  3. crank
    crank
    :lease: come on guys help us out here somebody must know :smashin:
  4. jtf
    jtf
    Nov 19, 2004
    220
    colchester
    +7
    :rolleyes: hello anybody, i think we are alone here :rolleyes:
  5. peterakastorm
    peterakastorm
    It will downscale it... as far as I know 1080p is 1920×1080 so the PV500 isn't capable of showing TRUE 1080p, because of it's lack of resolution - however, it will downscale it to 720p, probably.
  6. jtf
    jtf
    Nov 19, 2004
    220
    colchester
    +7
    i'm downloading a 1080p trailer so will try it later. hopefully it'll play
  7. kenji-san
    kenji-san
    the 1080p trailer won't show anything that you can't find out by setting powerstrip to 1920*1080p, and see if the pv500 displays the picture.
  8. llg
    llg
    No this panel does not support 1080P just I. But thats the offcial stance give it a go may work.
  9. jtf
    jtf
    Nov 19, 2004
    220
    colchester
    +7
    just tried the wmv-hd trailer of batman begins and it played it no probs
  10. MAW
    MAW
    Jan 24, 2002
    14,103
    Nr Dorking
    +411
    You are using a PC connection? As Kenji says, unless you are outputting 1080p from the PC, the PC is scaling the 1080p trailer to whatever the graphics output is set to. Good PC then, that's a lot of data, but no nearer knowing if the plasma will accept 1080p. Most won't, and Blu-ray/PS3 is touted as being 1080p.... 1st sky, then Sony throw is a curved ball. The laugh is on them though, Sony plasmas don't take 1080p either!
  11. Tejstar
    Tejstar
    Dec 4, 2002
    22,796
    London
    +1,080
    But I think Sony are just including 1080p to have a tick in the box. I'm sure most games will only support 720p and 1080i.
  12. MAW
    MAW
    Jan 24, 2002
    14,103
    Nr Dorking
    +411
    Very possible, yes. I guess it's a waiting game for all of us on this one. I did think Blu ray had seriously mooted 1080p though? But a kind of 'see what the feedback is like' serious.
  13. -Hitman-
    -Hitman-
    Mar 21, 2005
    4,807
    Sector7
    +1,112
    Your graphics card must be 1080p capable and setup to display a 1080p output within its settings.
    ATI have recently released 1080p support for most of their cards in the new catalyst drivers, you could also try powerstrip.
    But more importantly your screen needs to be 1080p compatible, which only a few are and to test it properly you would need to use the digital video standard input HDMI.
  14. kenji-san
    kenji-san
    why only hdmi, why not dvi or component?
  15. -Hitman-
    -Hitman-
    Mar 21, 2005
    4,807
    Sector7
    +1,112
    Most panels now support HDMI and this is the best connection at the moment and this supports the HD video standards.
    When using a PC you would want to take the best route, digitally! especially with Video formats, you could use dvi if thats the only digital connection but to go via component would set you into analogue and you would add DA conversion into the process!
  16. kenji-san
    kenji-san
    i'm not sure if there are gfx cards out yet that includes hdmi ports. but regards to dvi and component, even though they may be somewhat inferior techincally, in terms of just testing to see if pv500 were 1080p compatible, i think they would also suffice.
  17. -Hitman-
    -Hitman-
    Mar 21, 2005
    4,807
    Sector7
    +1,112
    Most of us use a clever DVI to HDMI cable for the card output to the panel and we are taking about using a PC to test for 1080p!
  18. kenji-san
    kenji-san
    my point was that even though component may be an inferior signal type, it's still applicable for 1080p testing. and ati gfx cards can also output component via dvi port with an adaptor.
    in other words, you can also use dvi and component from a pc to check for 1080p.
  19. chedmaster
    chedmaster
    Jan 29, 2005
    2,661
    68
    +28
    dvi and hdmi are exactly the same thing, just HDMI carries audio as well. they carry the same signal type. dvi is usually more PC compatible (for 1:1 mapping etc)
  20. -Hitman-
    -Hitman-
    Mar 21, 2005
    4,807
    Sector7
    +1,112
    In this case component is not applicable for this test as the adapter only supports up to 1080I and i already said that you can use the dvi connection if its the only digital connection on the panel!
  21. kenji-san
    kenji-san
    i'm pretty sure powerstrip can force it up to 1080p. and calm down mate, it's just a discussion. ;)
  22. -Hitman-
    -Hitman-
    Mar 21, 2005
    4,807
    Sector7
    +1,112
    The adapter is hardware selectable only(dip switches) and unfortunatley will not be forced by any software to work outside its spec!
    I am calm, it is only a discussion!
    No ill harm, mate! :)
