PV1 sub on laminate wooden floor.
anticlaus105
Have my sub placed as in the pic on lamminate flooring.
Very new to this and have read that some kind of matting for under the sub would improve performance (haven't even used it yet as waiting on 3806). It already has a rubber lining around the bottom.
Is this so and if so what is best and where do you get it from?
Cheers in advance.
rszee
I have a PV1 on real wood floor without any mat, don't know if it would make a difference but if you do decide to get one, post a reply with the difference either better or worse (or no difference)
rszee
Thinking about the mat issue, I don't think you will need it because the sub shell is totally 'dead' when using ( whack up the volume and touch the shell of the sub, you will feel nothing. This is one of the advantages this sub has over wooden box enclosures.
Trending threads
