Dialogue
I'm wondering if I can get some advice as I am new to home cinema. I have a recurring problem with my new B&W PV1 sub (part of an MT-30 package).
It all works well on most ocassions, but sometimes the PV1 stops working out during playback of a loud scene in a movie - the green light stays on, but the sub stops making sounds. If I take out the plug and reinsert it, or even switch it to standby and back to (A)uto, it starts working again.
It's almost as if the sub switches off to protect itself from damage. I'm playing back at +5.0db, but the amp is rated at 105W per channel so I wouldn't have thought it would cause a problem. In fact, as the sub is driven by its own amp, surely it protects itself from damage? I do sometimes see the driver moving quite a distance (say +/- 1cm) for low frequency effects - is that usual?
I have set the amp to LFE+Main, 80Hz crossover, set the crossover to 70Hz on the sub, and set the volume on the sub to just under mid-way. The amp is set to +1.5db for the sub, which seems minor.
Could this be a fault in the sub? It has happened when watching movies at 'reasonable' volume levels but for 1.5 hours.
It all works fine for music and normal TV.
Any ideas?
Any ideas?
