PV1 question?
paulst10
hi, anyone know if you can connect both the line level in and the rj11 cable on an AV reciever ?
and if so, they are both sending signals to the sub so do they conflict when watching movies??
many thanks
R
recruit
Paul - The only subs that can mix the 2 signals with good results are Rel subs, i do not think the results that you get will be what you want but it can be done.
If calibrated properly then all you need to connect is the Low Level input.
Regards
John
rszee
I have a PV1 but I don't think you can connect both at the same time. It does not say in the owners handbook either. Although I haven't tried it myself, I find using the low level input for both music and movies ok.
ppp65
I heard somewhere that you would get an improvement in sound by connecting the line level input. Try emailing B&W and asking them.
M
Mausse
Hmm interesting...i just ordered one...let me know what B&W answered! :hiya:
