We're migrating the forum software to the next major version and this will require the site to be down for the best part of Monday 16th.
More details here. Apologies for the inconvenience.
Pv-500 Vs 436xde
Discussion in 'Plasma TVs Forum' started by bobby100, Oct 23, 2005.
  1. bobby100
    bobby100
    Due to make the plunge but don't know which one too buy,or should i buy
    LCD,could someone help and give me your thoughts,or should i buy a bigger sceen, room size is 5m x4m,
  2. av2diefor
    av2diefor
    Decent size room bobby, 50" might be the one.
    I had a 50PV500 and sent it back, love my 506 though.
  3. pwood
    pwood
    Dec 6, 2003
    2,613
    Central Scotland
    +179
    Both are good but if you are considering wall mounting then the Pioneer is less hassle if you have to hide the wires ( plaster) into the wall due to the media box it comes with and more importantly its lighter. You might also consider the Panasonic PHd8 panel.
