PV 500 37 vs 42 inch
Discussion in 'Plasma TVs Forum' started by gibreal, Jul 15, 2005.
  1. gibreal
    gibreal
    Apr 10, 2005
    26
    Could some one tell me if the cases of both the 37 and 42 inch are identical( cept in size of course)
    All the original pics of them seemed very similar but after checking the panasonic site the 37inch seems to have a different style to the 42.
    http://www.panasonic.co.uk/plasma-tv/th37pv500ped/index.htm
    (now identical in look to the SD version)
    thanks
  2. Andywilliams
    Andywilliams
    Sep 27, 2002
    2,080
    notts.
    +63
    Wrong picture that is a 37"pe50 pv500s both look the same check them out on avlands website.
  3. Sulis
    Sulis
    Mar 29, 2004
    577
    Bath
    I'm pretty sure that the side edges (with the speakers) stay about the same size as the screen size increases, so the 50" looks a bit more Pio-like. Panasonic do seem to be 'featuring' more black edging on the screen itself, which confuses things as well...
  4. SimonMallion
    SimonMallion
    Feb 15, 2005
    78
    Panel resolution is different:
    TH37PV500:
    resolution: 1024 x 720
    TH42PV500
    resolution: 1024 x 768
  5. leeboy22001
    leeboy22001
    Apr 18, 2005
    1,308
    63
    +127
    panasonic cock up, the 37 incher is the same style as the 42 incher, what you see on there website for the 37pv500ped is actually the 37pe50ped
  6. gibreal
    gibreal
    Apr 10, 2005
    26
    hate to say it but I think the 50 chasis looks better than the 500 one.
    Not a fan of the shiny "gloss" type finish of the 500. Just my opinion tho.
    Ordered the 37 "500 all the same tho.
  7. Andywilliams
    Andywilliams
    Sep 27, 2002
    2,080
    notts.
    +63
    :rotfl:
  8. MokerJoker
    MokerJoker
    Dec 10, 2002
    130
    +6
    Same here. But I've gotten used to it and it doesn't look that bad at all now.
  9. leeboy22001
    leeboy22001
    Apr 18, 2005
    1,308
    63
    +127
    i personally think the 50 surround looks cheap :rolleyes: whereas the 500 surround looks classy :smashin:
  10. neurotoxicity
    neurotoxicity
    Jul 17, 2005
    How much diffferent would this make in viewing?
    I guess that the 37" version wouldn't have any scaling with HD images? Whereas the 42" would be better for "normal" PC usage?
    Or am I missing something here?
