Diaphone
I have a Q Acoustics S700 subwoofer which has developed a puzzling hum.
It is silent when switched on, but hums as soon as anything is plugged into either - or both - RCA inputs. By anything, I really mean anything. Plugging in a lead on its own causes it to hum, whether the lead is connected to the amp or not. The longer the lead, the louder the hum. As soon as the centre pin of the lead touches the inside of the socket, the hum starts. If I touch the pin on the other end of the lead, the hum becomes louder. It does the same if I touch it with another lead. It behaves identically whichever of the two inputs is used.
The hum is at the 50 Hz AC mains pitch (I checked it with the piano). The sub is powered by a two-pronged mains lead. I have tried different mains sockets, two different extension leads, and directly into different sockets. I have switched off and unplugged every thing else in the room, and I have tried the subwoofer in the middle of the room. But all to no avail. It's the same with everything I've tried. Nothing stops the hum, apart from removing the RCA leads.
Any thoughts or suggestions will be gratefully received. Thanks!
