Puzzle - Suddenly no Freesat signal with Panasonic DMR-BS850EBK Twin Freesat Tuners 500GB HDD Blu-ray Recorder
Mel_P
Hello - my ancient but treasured device was working OK last week - 90% strength on signal - recording OK - BUT then suddenly the tuner says "no signal on either of the tuners. I know it's old kit - but it did what I wanted. Recorded to HDD, archived to bluray.
I thought - ah must be the LNB - been outside since 2010 or before! So ordered a new dual LNB. SAME PROBLEM. Tuner says satellite cannot be found.
Amazon product
"SLx LNB Twin Output, 4K Satellite HD 2 Output KU Band Universal for SKY HD/Freesat HD with MK4 Bracket"​
Got up ladder to replace the LNB. Bit corroded but removed cables, swopped LNB. If I cover front of LNB with hand signal goes down of signal strength meter. Red LED is lit showing power supplied to LNB. Did a factory reset on Pansonic. No difference.
SO - is there some known failure mode of the Panasonic box "Freesat" section? I dont want to bin the Pansonic and spend £250 on a 1TB HDD replacement unless I an sure the new box will work?
Any advice / test procedure please? Thanks, Mel
winston2010
Maybe the dish has moved in the recent storms.
Try your ancient treasured device on someone else’s known working dish.
Randomly changing parts such as a not very old LNB is pointless and a waste of money. I have LNBs from the ‘90s still working fine.
Clem_Dye
In my experience it's luck of the draw when it comes to LNB quality, but a good one should last a long time, especially if it's sheltered from the weather. That said, I had a relatively new LNB that would intermittently give no signal.
I'd start by getting the dish alignment checked by a professional. He/she/they can test the LNB to see what's going on, check alignment, signal and so forth. I suspect that on this occasion, it's the Panasonic that's developed a fault, especially as it's fairly long in the tooth. If so, it might be reparable. A Panasonic service centre is your friend.
Samsung S95B QD-OLED Review - A Quantum Leap for OLED!
