Putting Enigmah video selector on Hard Drive
Discussion in 'Nintendo Forums' started by Jules12, Oct 17, 2004.
  1. Jules12
    Jules12
    Oct 29, 2001
    271
    Frinton on Sea
    +10
    Can someone tell me the file I need to FTP into the e folder of the x box to get this working. Is it the ISO file ? (beacuse this doesn't seem to work.
    Also does it need to have a default.xbe in the folder as well?
    Please help I am losing patience
  2. explicitlyrics
    explicitlyrics
    Apr 26, 2003
    1,149
    41
    NW London
    +18
    you need to extract the files from the iso.
    search on xbox-scene.com for something like xISO to do this. Inside the ISO there will be a few files and a few folders (one file being a default.xbe).
    You need to copy this contents of this iso onto your xbox in a folder called Enigmah (or anything you like)
  3. daz500
    daz500
    Oct 10, 2004
    47
    Belfast
    has your xbox been chipped or had a soft mod already applied?
    are you familiar with FTP'ing ?
    how does your menu reference games/apps folder on the drive? Mine automatically updates the menu with anything in the e:\apps, e:\games as well as f:\apps and f:\games.
    if need be I can send you via email the necessary enigma utility
  4. harrisuk
    harrisuk
    Jan 24, 2003
    5,328
    71
    +58
    If your system is already modded and have the HD loader software installed you can probably use this to install to HD from a dvd copy of it.
  5. Jules12
    Jules12
    Oct 29, 2001
    271
    Frinton on Sea
    +10
    Thanks for your help guys, I have done it now. The problem was I was using thew wrong files, I needed to extract the files from the ISO first.
    Thanks again
