Putting CD music on DV
Discussion in 'Camcorders, Action Cams & Video Making Forum' started by jezgroom, Dec 27, 2001.
  1. jezgroom
    jezgroom
    I want to buy a digicam which I can add music from a CD source really easily. I think the best / cheapest option is maybe the Canon MV400i and then plugging the CD directly to the camera and pressing start/stop a lot ! I know that linking to the PC will be better but I wouldn't mind starting gently ! Any thoughts ?
  2. colinrbarrett
    colinrbarrett
    Bear in mind that you'll probably be erasing sound previously recorded on tape, unless you're using an audio dub facility. Trouble is that this normally only gives you 12-bit 32Khz audio, which falls far short of the CD's 16-bit 44.1Khz spec.
    Better if you can wait til you can capture video into a computer then rip the CD tracks directly into the program.
    - Colin
  3. Guest
    The Panasonic NV-MX7 has a function where you can send music from a Hi-fi onto the memory card. So it works like an MP3 player or something. If you really want this though you will have to pay a bit more than you would be paying for the MV-400i.
    As far as I know this camcorder has very good picture quailty and sound quality too. Probably why it more expensive.
    I may be buying one tomorrow.:)
    I haven't read too much about this camcorder though so hopefully I'm not making a big mistake :confused:
