Putting a centre speaker on its side
J
Jimmysil
This may seem a daft question, but is there any reason why its not a good idea to put a centre speaker on its side.
Will this have a bad effect on the sound ?
The reason I ask is my new centre speaker (MS 905c) is a little large and would prefer it to go on its side.
Ed Selley
AVF Reviewer
No problem :smashin: Just try to keep the tweeter near ear level. Used to have a 504 as a centre rear and that was vertical.
J
Jimmysil
Thanks for the info Tons
I am very happy the 905c and my 903s can I add. :D
Regards
James
Nimby
Putting it on its side might affect your center speaker's sound distribution in the room.
Having a drive unit either side of a tweeter must have a specific design purpose. Lower reflection from side walls perhaps due to a shaped (narrow) polar distribution pattern? For a more beamed effect at the listener. Better articulation on dialogue without delayed [phase shifted] reflected sounds spoiling clarity?
Best bet is always to simply to try it and see if you can hear a difference. If you can't, then there's no need to worry. Is there? :)
Nimby
Ed Selley
AVF Reviewer
You are right but unless his room is very good indeed, there are umpteen other things that will get in the way first. Given that we have to voice centre speakers for a fairly large variation in mounting heights, turning it on one side will not prove very significant.
LG SP11RA Soundbar Review Coming Soon to AVForums
