Purple Spot on projected Image - Panasonic PTL -701e
Discussion in 'Projectors, Screens & Video Processors' started by Nexus6, Mar 11, 2002.
  1. Nexus6
    Nexus6
    I recently (Aug 2001) purchased a LCD projector for my Home Cinema Set-Up. It is the Panasonic PTL 701e Model, 1000 ansi lumens and a very quiet 28db Fan. Everything was fine running with Composite, RGB via computer connection and S-Video. I run the projector in lower power mode which cut's fan noise to a minimum which means I don't have to have the Sound too loud and wake the neighbours.
    I have used the Projector to watch mainly films and the bulb counter shows that it has been active for 87 hours total since August 2001.
    The problem is I now have a purple spot that has appeared on the very bottom of the projected image, this appears not to effect the image that is projected when it is in 16:9 mode. I rang the supplier where I purchased the projector and I was told that it probably was dust on the LCD panel, if it was not this it could well be a hotspot.
    Does anyone know if this sort of thing is common, the bulbs are suppose to last 2,000 hours more if on low power setting. Do I have a case for repair and will my gurantee be valid. I use a white roller blind to project onto, it's the blackout type which is fairly thick and has been very good. Could this have caused any problems?
    Any ideas please, appreciate it.
  2. jrwood
    jrwood
    If it is purple on a white background, it's a stuck-off green pixel.
    If it is black on the green background, then its a stuck green pixel.
    If it is purple on only a black background (tough to see), then it is a stuck-off red and blue in the same exact pixel location which would be very rare!
    If it is black on the magenta background, the above assumption is correct. The best way to test this is using pictures of solid colours. It may be a dust problem, you could try sucking dust out of the projector using a hoover, be careful though as you dont want to do any damage. You might not be able to get to the panels though, or maybe its something on the lens therefore try wiping it with a suitable cloth which wont scratch the lens.
    James
  3. mysphyt
    mysphyt
    Do they look like this "blob"? If so it is likely dust in the lightpath, try cleaning the LCD panels with "air in a can" type cleaners. If you defocus the projector you should be able to see the dust clearly on the screen. Some suggestions on how to do this here.
    [​IMG]
    Do they look like the blue blotches (fog) at the bottom of this picture? If so, it is likely a heat damaged or delaminating LCD panel and should be sent in.
    [​IMG]
  4. Nexus6
    Nexus6
    Thanks very much for the replies.
    I haven't had chance yet to action the suggested solutions. It is not like the blueing at the bottom of the Shrek still, it is a small purple blob/spot. I will try cleaning the panels with a small keyboard hoover and most apparent the lense. I have cleaned the filter thinking that it could have been a build up of heat that has created a burn although I hope not.
    I will take a picture with a digital camera and submit that if there is no improvement. This will give a clearer picture as to the problem.
    Again thanks for the tips.
  5. hekke
    hekke
    Jan 18, 2011
    Hello,
    I had the same problem. Iopened my projector (BPP Dataview C180) and saw that the filter for the green color has suffered heat damage. Does anyone know where I can buy replacement filters? Is it a standard size? Has anyone heard of the brand before? I tried to search the website of the manufacturer but had no luck :thumbsdow.
    Can someone help me :lease:
  6. TimeWarden
    TimeWarden
    Feb 5, 2013
    3
    Hi guys, is this what you're talking about, if not can someone tell me what's going on with my projector?
    [​IMG]
