Purple patch
tuftylover
I have a big purple patch in the middle of the screen but in never seems to be the same shape and you can only see it on light backgrounds,is this plasma leakage
arenaman
Sounds like it need re gassing
arenaman
Just messing, regassing is an urban myth, what TV is this? it was a common issue with 2010 C series Samsungs but at 7yr old and you might struggle to get any fix for free
stucarblne
It's a voltage problem basically.
Either the way it's computer driving algorithms are changing and/or an internal board problem
stucarblne
so will it get worse do you think and I'm presuming its destined for the recycling if not
I don't really know tbh. Your best bet would be to phone and and ask an independent repair centre for an opinion firstly. If you phone Panasonic directly, they will try guide you down the most expensive route possible
