purple haze on pixel plus
Discussion in 'TVs' started by DoogyDawg, Mar 2, 2003.
  1. DoogyDawg
    DoogyDawg
    Nov 27, 2002
    182
    Cardiff
    +3
    if there is a white image on the screen I can see a very light blue haze around the edge of the screen, does anyone else get this, also stands out a bit more in the bottom right of the screen as if it hasnt degaused.
    also...my sky box is on rgb 2 and when I switch it on the tv will show the sky menu as 4 boxes which roll across the screen then it comes up ok, as if it is doing something while switching, any ideas ?
    cheers.:hiya:
  2. Italo Tettoni
    Italo Tettoni
    Feb 25, 2001
    It's colour impurity in the tube, you can't do anything to fix it, short of buying a new TV. I had a 9617 model and it had the same colour impurity and also had clearly visible vertical bars on the tube. After the third P+ TV with the same problems I returned the TV and got a different brand altogether.
    [edited by moderator : please do not post slanderous comments without proof.]
    Italo
