Purity problem on JVC 36" tv
Discussion in 'General TV Discussions Forum' started by charles, May 25, 2005.
  1. charles
    charles
    Jul 6, 2001
    1,360
    63
    norwich
    +176
    In December I purchased a JVC HV36 tv.It has now developed purity problems- a faint yellow patch on the right hand side of the screen.This is most noticeable on B/W programming.The engineers agreed with the problem but JVC say it is within specification.An easy get out clause.The engineers have said that replacing the tube may cure the problem but there is no guarantee of success.The dealer will not refund the purchase price unless JVC accept the set as faulty.Has anyone had any similar problems to mine?and how were they solved? either with JVC televisions or other makes.
    Thank you
    Charles
  2. JayCee
    JayCee
    Jan 20, 2004
    22,330
    Lanarkshire
    +2,327
    Can you give the Full model no?
  3. charles
    charles
    Jul 6, 2001
    1,360
    63
    norwich
    +176
    Thanks for such a speedy reply.
    The exact model number is HV36P38S
    Charles
