Pure Evoke 3 Firmware update Probs
Discussion in 'Music Streamers' started by robzter, Jan 4, 2007.
  1. robzter
    robzter
    Aug 25, 2005
    468
    Fulham
    +6
    Have updated my new evoke 3 with the 2 firmware updates on the Pure website and everything seems as normal apart from the fact the remote now doesnt turn the radio on,only off.and i have to press the standby button to turn it back on again.any tips?
  2. ProfessorYaffle
    ProfessorYaffle
    Feb 6, 2006
    553
    28
    +85
    Have you powered it off completely (unplug from mains) since the upgrade?
  3. robzter
    robzter
    Aug 25, 2005
    468
    Fulham
    +6
    yes i have.
    i have it on re chargeable batteries as well
  4. ProfessorYaffle
    ProfessorYaffle
    Feb 6, 2006
    553
    28
    +85
    I asked because Pure's The Bug (which I have) requires a complete power-down after updating the firmware to ensure stability. It doesn't have batteries, so I'd assume in your case you'd need to remove those too. A complete reset (hold Menu button?) is always advised too, so you may wish to give that a try as well. Fingers crossed...
  5. robzter
    robzter
    Aug 25, 2005
    468
    Fulham
    +6
    nope tried everything..... i was thinking maybe i should restore factory settings..is that possible? undo the updates i installed?
    Thanks again.
  6. ProfessorYaffle
    ProfessorYaffle
    Feb 6, 2006
    553
    28
    +85
    Yes, just install the previous version as you would a new version (if not available online, it probably saved the old firmware in the PC folder you installed the upgrade from, as that's what The Bug does)
