Purchasing first system advise needed.
Discussion in 'Hi-Fi Stereo Systems & Separates' started by Nik555, Jul 2, 2005.
  1. Nik555
    Nik555
    Jan 15, 2005
    1,503
    48
    Bebington, Wirral
    +96
    Good evening,
    Iam looking at purchasing a Arcam DV79 DVD player, a Arcam AVR300 AV Amp, and B&W's MT30 speaker pacakge. (as a first system)
    Just wondering if this is about the best I can get for the money and will it be any good?
    Also what cables would I need to hook it up to a Loewe Nemos and Sky box?
    Thanks very much for any help, Nik
  2. OneDesi
    OneDesi
    Mar 10, 2005
    8,513
    Black Country
    +255
    you dont say if you are buying new and what you are buying for (AV or 2-channel mainyl?).
    Having said that I think the setup is awesome but the speakers are the weak point (the Arcam stuff could work with a lot better stuff).
    Also, the AVR250 is as good as the 300 and saves you £300 (only real deciding factor is room size!).
  3. Nik555
    Nik555
    Jan 15, 2005
    1,503
    48
    Bebington, Wirral
    +96
    Hi, thanks for the reply.
    The system will be new and I will be using it for movies and CD's.
    Whats wrong with the MT30's and what would you consider a better buy?
    Cheers, Nik
  4. OneDesi
    OneDesi
    Mar 10, 2005
    8,513
    Black Country
    +255
    Nik
    I don't think there is anything wrong with the B&W its just that I sold some orb audio imports from the states recently on this forum and these are like the Anthony Gallo just cheaper and better (compared to the A'Diva in my opinion). a 5.1 set of these with a sub bought in the UK will set you back about £6-700 and they are very good with music as well.
    Also, it depends if you can house larger speakers in your room as I quite like some of the larger Monitor Audio Radius stuff (R275 floor standers at the front with some R225's etc) - they come in a raft of colours (even white) and I think they sound awesome!
