Punched vhs tapes
Discussion in 'Digital TV & Video Players & Recorders' started by Ricky27, Feb 23, 2002.
Tags:
  1. Ricky27
    Ricky27
    Feb 8, 2002
    1,975
    Norwich
    +220
    Hi,i recently purchased a s-vhs vcr which im very happy with,and while looking for some svhs tapes on the net,read that it was possible to use vhs tapes to record the svhs signal on.
    I dont mean svhs-et,but the proper s-vhs format (my panny has both)
    So how does 'punching' a hole in the bottom of the vhs tape fool the video into thinking its really a pukka S-VHS tape?
    cheers.
  2. Garrett
    Garrett
    Apr 21, 2001
    43,260
    2
    167
    The best thief you'll never see.
    +8,178
    I think there is a trip lever that when you put a S-VHS tape in the lever goes up hole. This then tells the machine the tape is S-VHS. Similar to the slots in a cassette tape for normal/chrome/metal.
    You are better of getting a cheap source S-VHS tapes than putting a hole on a normal tape.
