Pulsar points and AVR300
Discussion in 'AV Receivers & Amplifiers' started by barnythebear, Jan 13, 2005.
Tags:
  1. barnythebear
    barnythebear
    Jul 6, 2004
    152
    leicestershire
    Are there any issues with removing the rubber feet from the AV300 or any other arcam kit? I've just picked up two sets of pulsar points and would like to use them under the AV300 and my P25 power amp. Not too worried about the power amp as the weight is not that great and could just put them under the base as I've done with my CD player. However, the 300 is a different matter and I wonder if the base could carry it. I do not want to put them under the feet as it makes the kit stand too high, so can I remove the feet without doing any harm. :confused:
