Pulp Fiction - PAL or NTSC
Discussion in 'Movie Forum' started by guyb, Aug 23, 2002.
  1. guyb
    guyb
    May 20, 2001
    657
    Leamington Spa
    +5
    Hi all,
    I don't know which version of Pulp Fiction: spec Ed or Jackie Brown: spec Ed to get - R2 or R1. The things that make my mind up are video quality and packaging.
    I have a PAL Sony 32inch widescreen with NTSC capability and a Sony DAV-S500 DVD Player.
    If the transfer on the R1 and R2 where identical, which will be better video quality - PAL or NTSC
  2. kevb
    kevb
    May 16, 2002
    1,099
    41
    About
    +3
    I probably get flamed for saying this. If the spec's of the disks are the same and the video transfers are of equal quality. I would go with the PAL version if you only have a widescreen TV. If you intend to get a projector some time soon go for the NTSC.
