Pull-up screen question
Discussion in 'Projectors, Screens & Video Processors' started by Wild Rumpus, Jun 29, 2005.
  1. Wild Rumpus
    Wild Rumpus
    Mar 30, 2005
    138
    Erskine
    I have changed my original plan to buy a large HD Plasma and have bought a 37" SD plasma. The second part of my new plan involves an HD projector :D I have decided that I don't want a screen mounted permanently in my living room and the ideal solution for me is to use a pull-up screen. However, I want to use the pull-up screen on top of my (atacama) AV stand. Is it possible to use the pull-up stands without fully extending the screen? If I have the screen with say 30" of black area at the bottom on top of my AV stand the picture will be a little too high for comfort.
  2. derekn
    derekn
    Jun 8, 2004
    648
    28
    Bristol
    +31
    The Draper Road Warrior will do what you want. The clue is the support system - if it's a fixed rod then it will be all up or down, if it's a pneumatic "trellis" then it will stop where needed.
    Good Luck,
  3. LFCRules
    LFCRules
    Sep 3, 2004
    2,670
    +188
    I've got a DRH Easy screen, and it should do the job you require. It ain't cheap, but very sturdy. Definately worth a look.
    DRHEasy
    Andy
