Pull Down LCD TV
Discussion in 'LCD & LED LCD TVs' started by rsa, Dec 30, 2004.
  1. rsa
    rsa
    :blush: Hope this is the right forum :lease:
    I want a small LCD type TV that will swing down from under a kitchen unit.
    I have absolutely no idea where to start.
  2. kwazemowdoe
    kwazemowdoe
    No idea if this will help but there is a TV advert on at the moment for Magnet kitchens which shows exactly such a screen.
  3. rsa
    rsa
    Yep Thats what her indoors has seen. I have to put it into practice :-(
  4. kwazemowdoe
    kwazemowdoe
  5. sparkz
    sparkz
    Nov 21, 2002
    219
    19
    Southampton
    You can get flip down mounts for up to 15" TVs like this one or the LCD005 from here.
    Sharp in the US used to have a model suited for the kitchen with a special mount but I can't see that any more.
    Hope that helps...
  6. Up The Spurs!
    Up The Spurs!
    try ebay - you can pick up imports with only 7" screens for 80/90 quid!!!!
  7. rsa
    rsa
    Nice one peeps
  8. rsa
    rsa
    Yep its a bit ugly
