PTAE500 - suggested DVD recorder source
Discussion in 'Projectors, Screens & Video Processors' started by 69COU, May 17, 2004.
  1. 69COU
    69COU
    Feb 8, 2004
    835
    +84
    As part of my plan to set up a Panny PTAE500 and screen in my evening cinema room, I felt it would be worth an upgrade to my current DVD player Panasonic RV31 which can go in the family sitting room.
    I am concidering a DVD / recorder as main sources in viewing room will be SKY+ & DVD.
    Thinking of another Panasonic unit as remote control compatability etc and in the past have proved reliable.
    Looking at the DMRE85 see
    http://www.panasonic.co.uk/dvd-recorders/dmre85hebs/index.htm
    Questions.
    If i use RGB Scart out of digibox into DMRE85 could i just then use the component to projector for viewing DVDs or Sky? :lease:
    Details of inputs/outputs attached.
    Video System
    PAL colour signal, 625 lines, 50 fields / NTSC colour signal 525 lines, 60 fields
    Recording System
    MPEG2 (Hybrid VBR), MPEG4(VBR)
    Input - Video in
    AV1/AV2 (21 pin), AV3/AV4 (pin jack)
    Input - S-Video in
    AV2 (21 pin), AV3/AV4 (S terminal)
    Input - RGB in
    AV2 (21 pin) (PAL)
    Output - Video out
    AV1/AV2 (21 pin), Video out (pin jack)
    Output - S-Video out
    AV1 (21 pin), S-Video out (S terminal)
    Output - RGB out
    AV1 (21 pin) (PAL)
    Component Video Out
    Y:1.0 Vp-p; 75 ohm, PB:0.7 Vp-p; 75 ohm, PR:0.7 Vp-p; 75 ohm
    :thumbsup:
    What alternative would you suggest othewise.
    I am trying to minimise cables from one end of the room to the other 16ft as wife will go mad (she has not figured out conduit across ceiling to Projector will be about 5ft)
    cheers
