PTAE200-should i buy?
Discussion in 'Projectors, Screens & Video Processors' started by lotusman1, Jul 29, 2003.
  1. lotusman1
    lotusman1
    Feb 13, 2002
    257
    cheltenham
    Have seen what i think is a good price with a free
    sony w/s screen for this projector (£999 inc vat and del)should i be biting their hands off and should i get a different screen as well?
    Thanks in advance.
  2. dapex
    dapex
    Jul 21, 2003
    1,082
    38
    +11
    where did you see it at that price????
  3. dapex
    dapex
    Jul 21, 2003
    1,082
    38
    +11
    Any chance you can tell me where you saw this price???
    Dave
  4. uksteve69
    uksteve69
    Jul 16, 2003
    70
    Telford
  5. lotusman1
    lotusman1
    Feb 13, 2002
    257
    cheltenham
    Yes you are correct steve,but shoult d i be buying
    it??????
  6. dapex
    dapex
    Jul 21, 2003
    1,082
    38
    +11
    A lot of people here have the 100 and this is even beter and a decent size screen to boot. You may as well try to work out if the screen will be big enough, if not then you will have to think about the added expense of a bigger screen.
    People on this forum are trying to find the 100 as cheap as possible and they only seem to be able to get the 100 for about 800 and the contrast ratio is a lot better on this one.
  7. theritz
    theritz
    Aug 17, 2002
    2,451
    Ireland
    +27
    Have you seen the projector in action ? Do you like the image it displays ? Is the price within your budget ? Will it suit the location where you intend to use it ?
    Asking "Should I buy it" based on the lowest price you've seen is not the only consideration.............. would you happily spend about a grand if someone here just says "Yes" ?
    Just my opinion, of course...............................
    Sean G.
