J
jayk
how good is the projector using progressive scan when using a high end dvd player!
Originally posted by Timh
Its pretty good, I have mine connected by a Toshiba SD-510, but a HTPC will give you a much better image. [/QUOTE
hi timh i cancelled the sony 900 and i am going to by the new denon 3800 this should give me a good picture.but why would the htpc give me a better picture
Progressive scan from a dvd player offers very good results, you only see the shortcomings when you get bright scenes like sky shots, you see some, but not bad vertical lines, which are produced by the projector scaling the image to suit the panel resolution of the projector.as a starting point will i notice alot of faults with the pj with progressive scan from the dvd player or will it be gradually over time before i start to notice faults with the picture or will i be thrilled with the big screen experience!!!!!!!!
Take a look here and here people like Kramer and Shockabuku are very pleased with the results from using their PC with the AE100 and some are using their PC for tv watching also.also with your comments about power strip and using a a pc i iam not very clued up on it i will have to find out some info were is the best way to get some info.
The screen has to be in the exact centre, I mounted my projector first and then marked the image on the wall so I had referance points to mount the screen.
Try and keep your projector leval, and try not to use any keystone at all.
