PTAE100E v HS1
Discussion in 'Projectors, Screens & Video Processors' started by mystex, Feb 11, 2002.
  1. mystex
    mystex
    Sep 15, 2001
    108
    Brighton
    I have had the SONY HS1 for about 2 months now and I'm beginning to see the shortfalls in this unit, the biggest one is not being able to ceiling mount it, I'm fed up with setting it up every time. I'm happy enough with the picture, although I'm really noticing the chicken wire effect quite a bit now(I have an 8ft screen sitting about 10 ft away). I've now seen all these threads about the Panasonic PTAE100E and I'm wondering whether to sell up and buy one of these instead? I'm sure I can sell my SONY for more than I'll pay for the 100E so it shouldn't be a problem cost wise. It only has 44 hours on the bulb life. Will it be worth it?
  2. gavan
    gavan
    Dec 20, 2001
    3,984
    Rapture
    +287
    If you sit 12ft away from an 8ft (wide?) screen you'll likely notice screendoor on ANY fixed panel device.
    Why not get a demo of the new PTAE100E ... I agree that not being able to ceiling mount the HS1 can be a real pain - probably the biggest flaw of the unit.
    What I wouldn't do is rush out to sell the Sony to buy something new just because it's the 'latest greatest thing' in this forum.
    Gav
  3. General Skanky
    General Skanky
    Jul 28, 2000
    4,252
    71
    Colchester
    +44
    Agreed.
    I thought the Sony was ok.
    It might be better to simply use a smaller screen as you sit close to the pic.
    The Panasonic vrs. Sony really comes down to what you want you want from it, excl. pic performance as they are fairly close. However, if ceiling mount is a priority then ok, go for it. Remember the Panasonic has a short throw lense, so at the same distance you would get a bigger(?) pic than you have now, possibly.
