ptae100 zoom
Discussion in 'Projectors, Screens & Video Processors' started by dis, Aug 11, 2002.
  1. dis
    dis
    May 20, 2002
    611
    43
    england
    +202
    hi...just like to know about the zoom i know that the keystone makes the picture worse but does the zoom,
    the calculation i got for the ptae is between 7'6in by 9'5in from the screen i would like the projector back as far as i can get it,
    i don't have the projector yet i'm trying to work out how far back i can go, thats why i would to know if the zoom will make the picture worse my screen size is 68inches wide by 38.1/4 inches high 16.9 ,hope you can help ......cheers.......dis
  2. Mr.D
    Mr.D
    Jul 14, 2000
    11,061
    +1,149
    To be honest its probably going to have a negligble negative effect on the picture. You might see a little softening of the image with the zoom at max but its doubtful it will represent any loss of detail beyond the resolution capabilities of the projector anyway.
  3. dis
    dis
    May 20, 2002
    611
    43
    england
    +202
    thanks for the info mr D sorry its a bit late cheers......dis
