PTAE100, WIDE480, Powerstrip & non-anomorphic
Discussion in 'Desktop & Laptop Computers Forum' started by Donnacha, Dec 10, 2002.
  1. Donnacha
    Donnacha
    Jul 4, 2002
    8,286
    York
    +4,434
    as a resonably new user to this stuff I have a question. I run my PTAE100 PJ with a laptop and Powerstrip for pixel perfect mapping. Nearly all of my DVDs are anomorphic and look great. However the odd DVD is non-anomorphic, i.e. plian old letterbox (e.g. Midnight Run). So when I play it in Wide480 mode from the VGA output of the laptop its squashed and wrong. In Wide480 mode you cannot select to zoom the pic. from the PJ, but you can in PowerDVD.
    Question is, is there any other way of doing this, e.g. thru a different resolution setting in PowerStrip or any particular setting on PowerDVD?
    Thanks for looking and any input
    Donnacha
  2. (GTV)Chris
    (GTV)Chris
    Apr 30, 2002
    706
    Manchester
    +3
    I always use the software to resize.
    I use TheatreTek as my player.
    Although, I suppose you change the projector priority setting?
    Haven't tried this so I might be talking rubbish.
    Chris
  3. Donnacha
    Donnacha
    Jul 4, 2002
    8,286
    York
    +4,434
    Cheers Chris,
    I think I'll resize using PowerDVD, unless anyone can think of a smarter way.
    Donnacha
