PTAE 500 image throw
Discussion in 'Projectors, Screens & Video Processors' started by Rob Pyatt, May 30, 2004.
  1. Rob Pyatt
    Rob Pyatt
    I have a Panasonic PTAE500, which I am absolutely thrilled with.
    At the moment, to fill my screen, the projector has to be in the middle of the room. Is it possible to increase the distance required (by around 12 feet or so) so that I can still fill the screen, but have the projector at the back of the room?
    I know you can adjust the soom etc, but these adjustments are not really enough.
  2. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    As far as i know there are no lens options on the AE 500 more expensive PJ often have 2 or 3 lens options available so you can select the correct one for your room. Short of having a new lens made or adding an extra lens to the front of the unit your only other choice is a ceiling mount, in middle of the room.
  3. harrisuk
    harrisuk
    Jan 24, 2003
    5,328
    71
    +58
    Move your screen closer. thats what I did !
