Pt-ae700 Extra Settings
Discussion in 'Projectors, Screens & Video Processors' started by jefcam, Apr 1, 2005.
  1. jefcam
    jefcam
    If you go in OPTIONS then OSD, then keep the ENTER KEY for 3 seconds pressed on OSD another menu will appear with advanced settings of calibration.
    The menus differ depending on firmware on projector.
    I had that problem of strange pixels appearing. i sloved it from this menu increasing the fan speed cause my problem was overheating.
    if any one wants more help i've got a thread from another forum. Just ask for it.
    thanks god!
  2. ptek
    ptek
    Clean your filter lately? :)
  3. jefcam
    jefcam
    yes i cleaned filter but problem solved caused i changed setting of fan from normal to high.
    the filter was clean. the projector has only few hours (30 hrs) run time and i cover it and take care of it. It couldn't be that it got dirty already.
