PT-AE500 optimal resolution from DVI input
Discussion in 'Projectors, Screens & Video Processors' started by Joel_Eriksson, Dec 18, 2004.
  1. Joel_Eriksson
    Joel_Eriksson
    I use the Powerbook G4 MAC's DVI output.
    Anyone who know how to get the proper 1280 X 720 resolution?
    Is that even possible?
    :lease:
  2. joncl
    joncl
    Yes, it is definitely possible, as I've done it. It wasn't so simple though as none of the 1280x720 settings in the graphics card drivers were compatible. I had to use powerstrip to create custom driver settings that were like those given in the AE500 manual. Unfortunately, this was done using PCs, and I don't know about MACS. But given a MAC equivalent of powerstrip, you should be able to do something. The results make it worth trying.
