PT-AE300 and RGB Scart
Discussion in 'Projectors, Screens & Video Processors' started by higenbs1, Jun 24, 2003.
  1. higenbs1
    higenbs1
    Aug 16, 2002
    460
    +11
    Is anyone using their AE300 with an RGB source through the SCART socket? If so, is it any good, and how does it compare with S-Vid and component inputs.
  2. themoron
    themoron
    Jun 30, 2001
    234
    Christchurch, Dorset
    I have my Sky/DVD/Xbox/PS2 all going through RGB Scart as it is the easiest method for me. I did try using a converter to Svid but it produced a wobble onscreen. I haven't tryed component yet but I think RGB is great, it produces a lovely picture (nice colours, tones, contrast). It can be a bit soft on the old focus which is helped by turning up the sharpness a tad.
    themoron :mad:)
  3. tonytigerrr
    tonytigerrr
    Dec 3, 2002
    92
    Merseyside, UK
    +3
    definite improvement over composite, although the difference isnt as striking as when I switch between composite and RGB on my rear-projection telly.
    When I compared it to S-vid from my DVD player I couldn't see a great deal of difference - in fact if I switched it a few times without looking I couldnt tell which was which just by looking at the image.
    I havent tried component yet, DVD through VGA on my PC looks great (even without 1:1 mapping) though.
  4. Jack the lad
    Jack the lad
    Jan 12, 2003
    2,079
    New Zealand was Nottingham
    +86
    I have my 300`s set up using both RGB scart and component to a dvd player. The difference is amazing. If you can go the component way. No comparrison.
