pt-ae100e component inputs variety
Discussion in 'Projectors, Screens & Video Processors' started by madhatter, Mar 14, 2003.
  1. madhatter
    madhatter
    What variety of comonent video input does the pt-ae100 have. My DVD player outputs RGB, picture on a standard 28" TV is fantastic. I want to buy the JS RGB-component converter and a pt-ae100e projector. The converter outputs YUV. Not sure what the difference is between YUV, YPbPr and YCbCr.
    Thanks in advance for any help offered.
    Chris.
    Just begining home cinema project.
  2. madhatter
    madhatter
    I have found out the answer. The pt-ae100e accepts YPbPr(CbCr) component inpuits.
    Y = 1V (p-p) 75r
    PbPr (CbCr) = 0.7V (p-p) 75r
    YPbPr signals = 525i(480i), 625i, 525p(480p), 750p(720p), 1125i(1080i).
    Now I just need to find out if the JS RGB-component converter (or any other) converts to this standard.
    Does anybody use a converter on a pt-ae100e.
    Regards
    Chris
  3. madhatter
    madhatter
    Had a look on the JS website and they have a technical Q & A section and I think I have found my answer.
    The following is from their site, I trust it is fine to print it here.
    Q. What is the difference between YUV, YPbPr, YCbCr and Y,Y-B,Y-R?
    A. YUV and YPbPr are the same and are commonly found on domestic A/V equipment. YCbCr is their designation for computer use, where each are represented by an integer value and CbCr offset due to having negative components. Y,Y-B,Y-R is a non-weighted colour difference signal and if mixed with domestic A/V equipment will give a colour tint. Both Y-B and Y-R are at higher levels than would be expected by domestic A/V equipment.
    And so it appears that I can use the JS converter to connect my DVD RGB out to the pt-ae100e comonent in.
    Let the project continue......
    Regards
    Chris
