PT-AE100 interference when using component and NTSC
Discussion in 'Projectors, Screens & Video Processors' started by niklaskarlsson, Apr 27, 2002.
  1. niklaskarlsson
    niklaskarlsson
    Hi all
    I´ve used my PT-AE100 for about 3 weeks. About a week ago I noticed something that looks like some interference from some sort of electrival signal when watching an NTSC disc via component. There are diagonal bars that comes from the left part of the screen and moves upward.
    When using NTSC via s-video or composit there is nothing. PAL shows no sign of these on component, s-video or composite. Only NTSC via components are showing this phenomenon.
    Anybody got any ideas or solutions? I´ve tried disconnecting different electronics equipment shifting powercords etc, nothing has workd so far.
  2. Timh
    Timh
    Sep 14, 2000
    5,259
    3
    3
    Altair-4
    +339
    which dvd player are you using?
    Check in the player menu if it is set to pal/ntsc or auto.
  3. niklaskarlsson
    niklaskarlsson
    I´m currently using a Sony DVP-S7700. There is no option in the setup to chose between PAL/NTSC/AUTO.
  4. tahustvedt
    tahustvedt
    Feb 11, 2002
    112
    19
    In a galaxy far, far away... (Norway)
    I use my VCR when watching TV on my projector. The VCR is connected through composite and the DVD by component. When the VCR is switched ON at the same time as I watch DVDs I get the same kind of diagonal lines you describe. When I switch off the VCR the lines go away. Somehow the composite-connection is interfering with the component. Maybe the interference is happening inside the projector, I don't know.
    Tor Arne
