PT-AE100 - adjusting min throw....can you do it?
Discussion in 'Projectors, Screens & Video Processors' started by AndrewJ, Feb 20, 2003.
  1. AndrewJ
    AndrewJ
    Feb 8, 2003
    56
    Surrey
    I have the ubiquitous AE100, which until now was sitting on the coffee table in use...
    I have now made a wall mount for it, to go on the wall behind the sofa. My problem is, that (whilst I was sure I calculated it properly- its clear now I didn't!) that the maximum throw for the screen size I had planned is too short....
    I have 4.5m from PJ lens to screen, and only really have room for a 232 (92") diagonal screen - 268cm (105") at a real push.... but even with the 105" screen I can't get the omage quite small enough.
    My question is - can you get supplementary lenses to adjust the focal length?
  2. rhinoman
    rhinoman
    Oct 31, 2000
    2,631
    71
    Herne Bay, Kent
    +33
    If you could get a lens it would probably be more than the cost of the pj:(
  3. Dekim
    Dekim
    Feb 9, 2002
    301
    +5
    Ive just done you a quick calc and at 4.5m fixed distance the min/max settings will give you a 119"/142" diagonal image :-(
    Deks
  4. AndrewJ
    AndrewJ
    Feb 8, 2003
    56
    Surrey
    Oh yes - worked that out this morning. As nice as a screen that size would be, it ain't gonna fit on the wall - well it would but would cover the door as well - plus 120"+ screens are £££
  5. rthorto1
    rthorto1
    There is actually a short throw lens (optional extra for AE300) that will reduce the image size!
    Harb has posted a photo attached to his 300 on this forum aswell as a distance chart (search back over the last 2 months for posts from Harb) and is currently doing some image Vs distance measures for me.
    Apparently is a perfect fit for the 100!
    Now the problem:( you can only import it from Japan:mad: it is a panasonic part but panny uk will not sell you one and it looks like they will not offer it for sale when the 200 and 300 are launched.
    I have the part No and price at home, will post them later time permitting! Cost is roughly around £200
  6. rthorto1
    rthorto1
    Part No. TY-LECTE300: $339 (40,000 Yen),
    If i take the plunge and order i will post my findings!
