PSU units.
Discussion in 'Computer Components' started by Techno Freak, Oct 11, 2004.
  1. Techno Freak
    Techno Freak
    Aug 24, 2003
    312
    16
    North-East
    Hello,
    I have a 4 or 5 year old PC that has completely died. I think it is the PSU.
    The PSU is an odd size and a replacement will not fit in the case.
    I have an older PC lying around that I know works, I was going to swap all of the newer bits into the old case.....but.....
    The PSU connecter on the newer PSU is different to the old one. Would this be AT v's ATX?
    If so, does anyone know a way of wiring the old PSU to the new motherboard?
    Is it simply a case of chopping all the wires off each motherboard connector and matching the colours like for like from the older PSU onto the newer MoBo connector?
    Thanks....
  2. KraGorn
    KraGorn
    Aug 30, 2003
    4,745
    68
    Warrington
    +27
    I really wouldn't rely on colour-coding, I'm not at all sure they're 'standard' .. you're almost certainly right about it being AT rather than ATX. Moreover, I think there's a BIG difference in that ATX systems are powered-on via a power switch connected to the mobo and detected by a trickle current coming off the PSU, whereas AT PSUs had no such power-control .. I don't know whether an ATX board would be happy without this or not.
    How is the dead one an 'odd size', how does it differ from normal ATX PSUs?
  3. Techno Freak
    Techno Freak
    Aug 24, 2003
    312
    16
    North-East
    It is smaller than a standard ATX replacement, I could probably cobble it in somehow but wanted to be sure that is was the PSU before buying a replacement.
    Thanks.
  4. Techno Freak
    Techno Freak
    Aug 24, 2003
    312
    16
    North-East
    OK, it is definatly the PSU.
    I tried a new one in it and that worked - but was way too big.
    Need to find a cheap, small PSU now.
    Thanks.
  5. KraGorn
    KraGorn
    Aug 30, 2003
    4,745
    68
    Warrington
    +27
    I think this is the first time I've seen mention of a non-standard ATX PSU, as opposed to the small units in micro-ATX boxes.
