PSU- undecided which one?
Discussion in 'Computer Components' started by fabryuk, Apr 19, 2002.
  1. fabryuk
    fabryuk
    OK, I have 3 options here, not sure which one is the most cost effective though. Ebuyer is selling 300W power supply for tenner.!!! and then I can replaced the fan to make it quieter (Papst fan, I think is 80mm, can anyone confirm that?). Second option is to buy a Enermax whisper 350W PSU which I think has fan control. The third options is buy PSU from quietpc for >£65 (BTW I don't think is justified to buy such an expensive PSU). Which oone of the above is the best solution to power a AMD Athlon 1.4 Gig??
    Thanks in advance.
  2. ReTrO
    ReTrO
    Jul 12, 2000
    3,507
    2
    71
    High Wycombe, Bucks, UK
    +59
    Personnally I am going to get an Enermax 350w PSU. Have had good reviews, seems to be quiet enough.
  3. buns
    buns
    Apr 29, 2001
    6,100
    58
    Belfast
    Obviously noise is one issue......but how about the quality of the power supply output? I assume that like everything else delicate and electrical, computer components will behave variably when the supply to them is variable?
    ad
  4. nutcase_1uk
    nutcase_1uk
    Apr 15, 2002
    479
    Essex, unfortunately
    +3
    Personally, I wouldn't trust a £10 PSU. I'm currently using an enermax, nto a whisper, but it's pretty quiet anyway.
  5. buns
    buns
    Apr 29, 2001
    6,100
    58
    Belfast
    Given I will be having my pc in a closed cupboard inside which resides both LCD projector and extractor fan, would you think that the noise level is still an issue?
    thanks
    ad
