Spoof
Hello,
not sure about this one so am after some advice. I have a shuttle jpc 775 with a 300W power supply which I use as a HTPC and gaming now and then (have E7200 at moment).
I want to upgrade to a Q9550 soon. Do you think my power supply has enough wattage as I may also want to stick in a 6670 later on as well. Am little worried if it will handle it and also may need something other than the stock cooler to handle the heat as looks like they can get hot hot.
It is rated 95W TDP so I assume it guzzles up that 95W and no more so am thinking that it should be alright but any advice well taken.
Best Kaye
Best Kaye
