PSU - How hot??
Discussion in 'Computer Components' started by caylem, Sep 30, 2004.
  1. caylem
    caylem
    Oct 23, 2001
    85
    Feels like home to me
    I have recently bought a silenx 400w PSU, and am concerned about the temperature.
    I’m not sure if its faulty as it gets VERY hot. After 30 mins there is a lot of hot air coming from the rear fan. If I take the case of, the unit if also very hot. As the unit is sitting right by the CPU it’s putting at least an extra 8 to 10 degrees on the CPU
    I've e-mailed the supplier, but not yet had a response.
    How hot do PSUs normally run - should I be concerned?
  2. CodeThief
    CodeThief
    May 25, 2002
    660
    UK
    +5
    PSUs can get pretty damn hot if you've got a lot of stuff hanging off them. Especially ones with slow fans like I assume the Silenx one has. My Sparkle kicks roasting hot air out the back and it's been on 24x7 100% CPU usage for about a year now with no problems :)
    Dave
