PSU for P4
Discussion in 'Computer Components' started by Stereo Steve, Dec 7, 2003.
  1. Stereo Steve
    Stereo Steve
    Jul 11, 2003
    1,915
    38
    UK
    +7
    Just ordered a Pentium 4 2.4. and an Asus p4p800 VM mobo to upgrade my system. Current mobo is an Asus CUSL2 running a Celeron 900. I have a Q Techonology PSU which I bought form QuietPC a couple of years ago and is still silent now.
    I hear that a PSU has to be P4 compatible. What does this mean and will mine be OK? DO I need any special connectors or anything. The Current 300W PSU's on QuietPC's site say they are OK but mine is a bit older.
    Just wondering if I need to get a new one as I need to order a new P4 cooler (Zalman 7000) and might as well get the new PSU at the same time. Any ideas?
    Cheers.
  2. loonatic
    loonatic
    Jan 4, 2003
    1,877
    41
    Springwell Village, Gateshead
    +16
    For the PSU to be P4 compatiable it has to have an +12v power connector.
    If you current PSU has an extra 4pin connector with yellow & black wires then you should be fine.
    The image below might help, it's the bottom left one your looking for:
    [​IMG]
    Cheers, Lee
  3. Stereo Steve
    Stereo Steve
    Jul 11, 2003
    1,915
    38
    UK
    +7
    Yep, got that. Thanks for your help.
