PSU and fans
jenic
Joined
Dec 10, 2004
Messages
3,099
Reaction score
251
Points
769
I am looking for a new PSU to replace my current standard one. The main reason is noise, i have heard of fanless PSU's but think that a very low noise one would be good enough. I want it to be less than 18db and i would like it to be blue lit. I'm not looking at spending any more than £50 but maybe could stretch a bit further.
I am also looking at replacing my 1 case fan and adding an extra 3. My current one is blue lit so i would like the new ones to be blue too. I want to spend about £30 on all 4 fans. I need 80mm ones and they must have a noise level of below 18db.
Also i would like to control 3 of these fans via a 5.5inch bay in the front of my PC, the fan control unit must not have usb ports on and must include the fan controls as a volume syle knob and temp monitor.
Any suggestions would be great!
adding an extra 3 case fans will probably add more noise, unless you run them at a very slow speed, in which case they will be doing nothing useful anyway... any more than 2 80mm fans is overkill I'd say..
£50 could be tricky for a decent, quiet, PSU... If you had the extra £15 you save from not adding all those case fans however.... :devil:
What case do you have - and how many fan mounts and what size are they? What power PSU do you need?
Adding more fans won't add more noise unless they're noisier than your loudest component. Your PC is only as quiet as your quietest component IYSWIM.
I replaced my noisy, sounds like a hairdryer psu recently with this Tagan one. I read a few reviews and Tagan seem quite popular, they do different wattages and some have neons, also they are modular which makes fitting a lot easier, and the inside of the case is much neater - the psu cables are properly sheathed so if you have a side window it all looks much nicer than those horrible molex connecters and leads.
EDIT: Also.... I stuck a pencil into all the fans (very briefly, one at a time) to momentarliy stop them spinning and find out which ones were making all the noise, psu was loudest, followed by the chipset fan (now replaced) and the top exhaust case fan (now slowed down by fitting a modded cable supplied very kindly by a forum member) :)
My case has 4 80mm case fan spaces and came with 1. My PSU is 400W so i guess that is what i need. I have a quiet fan on my CPU and my 1 case fan is pretty quiet. If the extra case fans aren't nessesary then i think the only thing i need to change is the PSU.
The number of fans you need largely depends largely the spec of your system.
Take your 4 fans and slow them down to 7 or even 5v this will greatily improve noise.
I'd do this first then see which is the next loudest component and think about addressing that next and so on until you get to the point you are happy
I
The bigger the fan, the less noise it'll make. Also, if your case has any of that fancy metal pattern crap, dremel it out, less resistance, less noise!
I've recently fitted an Enermax EG701AX-VE(W)SFMA 600W ATX V2.00 from www.overclock.co.uk which cost £93.91 inc.VAT, which is rather more than your £50, I know, but it's worth it. It's whisper quiet - my hard disks make more noise than this power supply, and I don't think I've had a power supply before which is so heavy (must be due to the solid copper heatsinks).
the *slower* the fan the less noise it'll make.
True, but everything else being equal a larger fan should make less noise for a given throughput of air.
Heh - yeah. That's because it'll be going slower :lesson:
dunamis
or two (or more) smaller fans...
The OP has room for 4 x 80mm fans - larger fans aren't a possibility.
2 x 80 mm fans shifting X cfm of air at 18dB are no worse than 1 x 120mm fan shifting X cfm of air at 18dB
so what's noisier, a room with one person talking at 40Db, or a room with 50 people all talking at 40Db? ;)
ooo ooo is that the same as 'what's heavier a ton of feathers or a ton of lead?' :suicide:
-- As an eBay Associate, AVForums earns from qualifying purchases --
2 Antec PSU's were tested in Custom PC this month, the SmartPower and the TruePower, one had a weak 12v, and the other blew up. See if you can find any reviews before splashing the cash....
There are some good reviews on the ebuyer site, i have also signed up for 3 issues of computer buyer for £1 so i hope that there will be something about PSU's in their.
I never got things really quiet with 80mm fans, but with 120s like the AFDP-12025B from http://www.quietpc.com/uk/casefans.php run at low voltage you have to stick your head in the case to hear it - runs at about 670 rpm.
Together with a http://www.quietpc.com/uk/amdcooling.php#ninja CPU cooler and another 120mm as a case fan mounted on squidgy mounting pegs my whole system is now really quiet. (and the CPU - AMD 64 3000) runs below 40C at full load).
(Zalman fanless video card cooler and northbridge is already a heatsink on my mobo)
Oh yes - mount disc on rubber grommets too....
Like mjn I don't rate Antec PSU that much, the one that came with the Sonata case was really noisy, and I had to replace that too.
Thouse AcoustiFan dustless Pootle mentions are very very good.
80mm fans such as Panaflo FBL801A can be made quiet though - you just need to run them at 5V.
Just tried this before i order the PSU and guess what, i was totally wrong. The noisy fan is the CPU cooler, it is just a cheap akasa one that was only a tenner but it did say quiet on the packet.
Anyway, now i want a very quiet cheap socket 939 cooler, any that are avilable at www.cclonline.com would be great as i live close to the shop. Also, preapplied thermal grease would be nice.
what case will it be going in? The Scythe Ninja is a great cooler if you've got a case big enough to take it. If you've got the room the Zalman CNPS9500 (with Blue LED) and Thermalright XP120 are also worth a closer look
It is going in a midi tower, dimensions Width - 200mm
Depth - 450 mm
Height - 410 mm
blue lit and quieter than the Antec ( i replaced 2 x Antec with these)
from £59 + P&P
seasonic s12 range
http://www.overclockers.co.uk/acatalog/Seasonic.html
read the reviews these are the best on the market for stability and noise
or go for a fanless PSU for over £100 such as the Antec phantom
yes better to have one 12cm fan than 8cm ones though slienx ones are supposed to be good i would prefer a fan controller ot running them at a slower speed
LG G4 OLED Best Picture Settings Out Of The Box - Filmmaker Mode!
Back
