PSPvideo9 "Your best settings"
Discussion in 'Playstation Forums' started by chaddy, Aug 13, 2005.
  1. chaddy
    chaddy
    Jul 7, 2005
    1,617
    48
    Manchester
    +66
    What are your best settings for movies on your memory stick when using pspvideo9.
    I've noticed that the upgraded version has some new settings.
    Video Settings Mode :- SP>CBR
    SP>FQ-VBR
    SP>A-VBR
    AVC-CBR
    What do these mean & which is best?
    Also anybody had a go with the PSPvideo9AVC program.
    If so could this be a sticky because i'm sure that people would like to know what settings are best & would like to add the 2 cents !
    If you do add your best settings, please add what size the file ended up at and a very small sample (if possible, "sorry if its rule breaking")
  2. meansizzler
    meansizzler
    May 11, 2005
    7,574
    104
    London
    +265
    I encoded this months ago at 1.4Mb/s, enjoy..
    Link
  3. chaddy
    chaddy
    Jul 7, 2005
    1,617
    48
    Manchester
    +66
    What settings where used for encoding !
    and that looks good quality.
  4. Munkey Boy
    Munkey Boy
    Nov 23, 2003
    16,516
    2
    Manchester
    +4,313
    I've been playing round with the settings myself recently, and for me it's all a bit trial and error. I've got a 1GB memory stick, so I can put a bit on there but as always its getting the balance between quality and quantity right.
    So far I've only been using the preset profiles, and I'm finding that the lowest watchable quality for a standard TV show (24, Band of Brothers) is the profile "368x208/29.97fps/QB7 Stereo/96kbps", which works out at about 200MB per hour, though this is a variable bit rate, so the size can vary. Pixellation is just visible, but not too off-putting. This means you can put about 4-5 hours of video on at once. If you go into the profile picker, you can see what settings this works out at.
    You can put brightly coloured programs (like the Simpsons, Futurama) at a lower quality and they're still watchable. Hope this helps!
  5. meansizzler
    meansizzler
    May 11, 2005
    7,574
    104
    London
    +265
    It was a high definition source which is why it looked so good, I think I used 368x208/29.97fps/QB7 I think..but there is a slight notice of frame drop so I reckon you should knock it down to 1.3mb/s
  6. dts borg
    dts borg
    Sep 5, 2001
    577
    Hornchurch
    +8
    Can anyone help me with a Video 9 question? I have use DVD Decrypter and Video 9 but I'm not sure if I have done the rigth thing as my PSP will not be here until 1st September......ok.....ok I here you :suicide:
    The movie waiting to be converted has six files:
    M4V10029 VTS_01_1, M4V10030 VTS_01_2 etc when I get the PSP and covert these files over will they play as one movie or will the movie be split in six parts :confused: I followed this here Seamonkey
    Thanks ;)
  7. chrislad
    chrislad
    May 6, 2005
    5,617
    83
    Rep. of Ireland
    +137
    If you have 6 files from using DVDecrypter, you're not using it right. I get 1 file, which I just convert with PSP Video 9. Re-read the tutorial.
  8. BuFF DaDDy
    BuFF DaDDy
    Jun 2, 2005
    3,287
    +146
    What size memory stick duo do you have, if its 1GB you need to turn off file splitting (Set to None), if its a 512mb and you film is bigger set it to 512mb and it will split the film in two.
    Ive got a 1gb so dont bother with the file splitting as its a pain watching one half of a movie then uploading the second half etc..
  9. MattTheBeanster
    MattTheBeanster
    Oct 23, 2003
    1,362
    Cornwall
    +89
    I use DVD Shrink, find it easier than decrypter. You can select which audio tracks and subtitles (if any) to export and edit the credits off before exporting.
    PSP Video 9 has a new version (v 1.62) and the settings have changed as from 1.6x the QScale values aren't the same as previous versions. I used to use QScale 4 and find i get similar sized files but much better quality using AVC (FQ i think) QScale 23.
    As far as i understand it PSPvideo9AVC has had it's functions (more or less) intergrated into PSPvideo9 now.
  10. papz
    papz
    368x208/29.97fps/QB7 Stereo/96kbps<<< you cant et 2hrs of movie with those settings?!
  11. chaddy
    chaddy
    Jul 7, 2005
    1,617
    48
    Manchester
    +66
    cheers papz will try.
  12. meansizzler
    meansizzler
    May 11, 2005
    7,574
    104
    London
    +265
    Not even with a 2GB Card?...hehehe
  13. jinky32
    jinky32
    Oct 17, 2004
    346
    +6
    i've just updated to v1.70 and am now having problems. I have my same profile, but now when i try and 'transcode' i get a fail message, then generating thumbnail message, then complete message and a puny 0 byte file in my folder that I can't play.
    as far as i can see the only new/altered setting is the mode selector - is this or am i doing something else stupid?
    not to sound too old or anything, but i liked it how it used to be in the good old days (or about 30 minutes ago)
  14. Steven
    Steven
    Senior Moderator
    Feb 1, 2005
    36,419
    +6,211
    Try creating profile again. Upgrading deletes saved profiles.
    At least the conversion screen is improved, so you'll know how long it'll take
  15. jinky32
    jinky32
    Oct 17, 2004
    346
    +6
    cheers mate. fiddled around and nothing worked so just reinstalled and it's ok. pc wierdness
