PSP WLAN Switch
Discussion in 'Playstation Forums' started by john2303, Oct 23, 2005.
  1. john2303
    john2303
    Jul 2, 2004
    285
    Aberdeenshire
    +8
    I am trying to connect the psp to my wireless set up and it keeps coming up with WLAN switch is not turned on!!
    How do I rectify this?
    John
  2. Pug72
    Pug72
    May 10, 2003
    2,347
    Hereford
    +406
    Turn it on???
    It's the switch on the left side.
    If you mean that the switch is on but isnt working, then it seems that your PSP is faulty.
  3. Forestred
    Forestred
    Oct 2, 2003
    297
    Norwich
    +6
    Why is there a switch to turn that on its really annoying?
  4. BuzzLightyear
    BuzzLightyear
    Jun 3, 2004
    167
    16
    The switch is there so that you have a choice to have it on or off - that way it prevents people moaning that you cannot turn it off :D
    Buzz
  5. figoagogo
    figoagogo
    Mar 29, 2005
    8,193
    +579
    Conserve battery power? :rolleyes:
  6. zantarous
    zantarous
    Dec 11, 2002
    2,491
    113
    +820
    And so that you can turn it off when you are in a place you are not supposed to have it on like a plane.
